Under The dash rig?
Old Jan 31, 2012 | 12:36 AM
lethaldomestics's Avatar
Under The dash rig?
I found these under the dash it has some home made jumper on to it. I am Having taillight issues also. could this have anything to do with it?
wires are green,green/white,and brown
Old Jan 31, 2012 | 12:40 AM
Re: Under The dash rig?
Also i found this.Name:  202_0050.jpg
Old Jan 31, 2012 | 11:07 AM
bump
Old Jan 31, 2012 | 01:09 PM
anybody?
Old Jan 31, 2012 | 01:40 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
WOW ive taken apart alot of 3rd gens but these connecotrs I have never seen. The first one the only thing i can think of is whoever had the car last made a home made bypass for the neutral safety switch. Not 100% sure thats what it even is. Try to trace back the wires as far as you can and see where they go and if there where spliced at all. It might help identifing them
Old Jan 31, 2012 | 06:49 PM
No they are not splced ad far as i can see. I would have to take the dash apart i suppose.
Old Jan 31, 2012 | 08:58 PM
anybody else?
Old Feb 1, 2012 | 09:57 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Both of those look kind of familiar from when I had the dash out several years ago.
Is this a T/A? From the wire colours, the first one looks like it MIGHT be the connector for the 'dimmer module', basically a power transistor mounted in a heatsink that controls instrument panel dimming. Looks like the module is missing, and the jumper is to keep the panel lights on full. Got no panel dimming? Afaik, T/A's only had it, not Camaros.
The second one - sorry not coming to me yet, I think it may have been for some option not installed on my car.
Edit: If it is the dimmer module, the brown wire comes from the park position on the headlight switch, might indeed have some effect on your 'tail-light issues' whatever they are.
Old Feb 1, 2012 | 10:02 AM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
the first picture is the connector for the remote dimmer switch for the headlights. it has been removed and bypassed to be on full power with no dimming function. you can buy the dimmer new at autozone for 20 something dollars
Old Feb 2, 2012 | 01:35 PM
WOW Thanks. Yeah my dash lights do not dim and yes it is a Trans Am. When i take this jumper out tho the tailights act differently. odd. thanks for the response.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
