89 2.8 starter relay
Old Feb 12, 2012 | 01:00 PM
Vicious's Avatar
Car: 89 firebird rs
Engine: 2.8
i have an 89 2.9 firebird
I have been attempting to jump the starter relay and been semi successful.
I have a wire going from the yellow thick wire to the green thick wire and when i go hit the key it cranks and it wants to fire up for like 3 seconds and then it turns off. i checked all the grounds from the car
I also have the orange vats wire off the key lock cylinder(it ripped off) if this helps....
Do i have bad ground somewhere?
Am i jumping the relay wrong?
Do i have to ground the relay through one of the wires
Any tips would be much appreciated!
Old Feb 12, 2012 | 01:11 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: 89 2.8 starter relay
if the starter kicks at all, the problem isn't the relay. A bad relay will prevent any power from getting to the starter.
Old Feb 12, 2012 | 01:31 PM
Vicious's Avatar
Car: 89 firebird rs
Engine: 2.8
well i connected a wire from the starter then i stick it on the postive post of the battery and it does the same like it wants to fire up but when i do it this way the car hesitates to turn over more
should i go check my starter at autozone?
(its like 1-2 years old)
oh yeah i did the relay jump because they dont sell them where i live and i have to order it and it will take like 3 days with a cost of 23$
(plus i didnt feel the relay click thats why i decided to jump it)
Old Feb 12, 2012 | 01:53 PM
58mark's Avatar
to me it sounds like your vats system is killing the engine because it detects a fault.
Unless I'm misunderstanding you, the starter is engaging... If that's the case, it's not the starter
read up on bypassing VATS, but not the starter relay, that's something else entirely
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
spartanreaper
Sep 25, 2015 07:22 PM
sahlomonic
Sep 20, 2015 07:15 PM
