Hmmming alternator
Old Feb 22, 2012 | 09:28 PM
Falconsfan's Avatar
Hmmming alternator
Hey guys. Got a problem. My alternator makes a humming noise when the ignition is off
And runs the battery down. Also the choke light comes on and the relay under the hood buzzes. Was fine till hooked msd up. But even when I unplug each wire still hums. Alternator charging. Its an 87 camaro 327 motor not .original. Any help would be appreciated . Thanks.
Old Feb 22, 2012 | 09:40 PM
spicyskater's Avatar
Car: 1987 camaro Z28
Transmission: manual
Re: Hmmming alternator
you having a stiky relay somewhere...i had same problem....i hapen to be relay hanging down in the fender next to the batery...when i opend it it was all rusted
Old Feb 22, 2012 | 09:47 PM
Falconsfan's Avatar
Yeah I noticed that one I actually unplugged it the light goes off but the humming still there
Old Apr 27, 2012 | 10:50 PM
87irocz1976's Avatar
I'm having the same problem, only mine hums when the key is on. When I unhook the brown white wire it stops. When I start the car the alt squeals like a loose belt but it's not. And is not charging the battery. Also alt get really hot really quick. It's also the 4th alt I've put on since the problem began. Any ideas would b greatly appreciated
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
