Coolant Temperature Sending Unit
Old Feb 23, 2012 | 12:47 PM
houseumbrella's Avatar
Car: 1992 Camaro RS
Engine: 305 Throttle Body Injection
Transmission: Turbo-Hydramatic 700R4 four-speed
I recently did the timing on my 92 camaro rs 305 and put a code reader up to it and it gave me a code 15. that's the coolant temperature sending unit. will this little sensor effect how the car starts? unless i pour gas in the throttle body it doesn't like starting. maybe just some faulty wiring somewhere?
Old Feb 23, 2012 | 12:48 PM
Car: 1992 Camaro RS
Re: Coolant Temperature Sending Unit
Also, the speedometer is about 10 mph off
Old Feb 23, 2012 | 04:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by houseumbrella
code 15.
If the computer is not seeing the correct (actual ) engine temp it can't supply correct amount of fuel needed
Possibly. check the 2 wires to the sensor and the connector
New CTS is only $14 and your stock one may still be the original
Old Feb 23, 2012 | 10:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
that's the coolant temperature *sending unit.
Coolant temperature *sensor
The sending unit is for the gauge.
Bubbajones_ya
Jul 6, 2024 08:32 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
hotrod1988
Sep 11, 2015 04:39 PM
Glowsock
Sep 5, 2015 07:48 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
