Left turn signal doesn't cancel
Old Feb 24, 2012 | 10:17 PM
92RS4US's Avatar
Car: 92 25th anniversary edition
Transmission: 700R-4
Axle/Gears: 2.73's
noticed on my '92 RS when turning left the turn signal does not cancel. Do I need the whole turn signal switch asm? is there a cancel cam? It's been so long since I've had to deal with these older ones I'm embarrassed to say I forgotten. I want to avoid taking the steering wheel off twice.
Old Feb 25, 2012 | 02:38 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Left turn signal doesn't cancel
if one side cancels but the other doesn't, then its pretty much a certainty the switch is bad.
Old Feb 25, 2012 | 07:37 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
When that happened to me I had to pull the steering wheel and put a new turn signal canceling piece in there. Its plastic and if one sides ear breaks off that side will not cancel by itself.
Old Feb 25, 2012 | 07:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
2 parts
the cancel cam on the shaft
http://www.ebay.com/itm/GM-VARIOUS-M...item19c87a8140
that moves the mechanism
http://www.ebay.com/itm/COLUMN-TURN-...item230dc83da6
Either could be broken
Old Feb 25, 2012 | 07:42 AM
92RS4US's Avatar
Axle/Gears: 2.73's
Thanks guys!
Old Feb 25, 2012 | 07:59 AM
Edwardgp's Avatar
Engine: 454-350
Be sure and get a steering wheel puller while your at it, they don't cost very much and the only safe way to pull the wheel.
Old Feb 25, 2012 | 08:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Pics of the cam dissembly/install (IIRC) here:
https://www.thirdgen.org/forums/susp...-steering.html
BTW, I replaced mine last summer. Bone yard piece.
JamesC
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
