help with wiring up shift light
Old Feb 27, 2012 | 07:11 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Hey guys so i have a autometer autogage tach in my car and it has the 2 wire plug for a shift light. Yesterday while cleaning out my car i found i actually have a shift light i can use. But it doesnt have a plug it has 3 wires, im assuming hot, ground, and tach feed cause it has the rpm selector on the back. Could i just wire the hot and the ground to the plug off the tach? And with it being a light does it matter which wire goes to which on the plug? The 2 wires to the plug are both black and im also assuming one hot one ground? Hope this makes sense, i can post pics if needed. Thanks.
Old Feb 27, 2012 | 08:03 AM
bigreed91's Avatar
Car: 1990 camaro rs
Re: help with wiring up shift light
heres some pics of it
maybe these wll better explain what im asking
Old Feb 27, 2012 | 08:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
It's not a light; it is a electronic device that reads the tacho signal from the coil and turns a light on
Check the power plug;
is most likely keyed so it only fits one way to the corresponding plug from the tacho it was intended for
If not keyed polarity prob won't matter
Old Feb 28, 2012 | 12:12 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Is that a pro-form shift light? If so, I have the same one and it is a standalone shift light. If there is a dial on the back where you can set the activation RPM, yes it is the proform. You run red to switched 12V (Gauges fuse), black to ground and the green wire goes directly to the coil.
The two pin connector on your autometer tach is for an add-on light you can buy from autometer that will only work with an existing tach. The proform one does not need a tach to function.
Old Feb 28, 2012 | 12:39 AM
bigreed91's Avatar
Car: 1990 camaro rs
Not sure on the brand it doesnt say, i know its a stand alone im just curious if i could run it as just a light by splicing it to the wires of the plug on the tach where an autometer brand light would plug into. If i did run it as a stand alone and ran the green wire to the same tach feed wire i ran for the tach could they both accurately run off the same wire?
Old Mar 1, 2012 | 09:29 AM
bigreed91's Avatar
Car: 1990 camaro rs
Well i wired it up the way i was asking, i didnt use the green wire off the light and just spliced the red and black into the plug on the tach and it worked so im happy. In the pic i had the shift point set at 2000rpm just to get a pic.
the light needs to be pointed a lil more towards me but i'll have to bend the bracket so i'll do that later.
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
