some dash lights work
Old Feb 29, 2012 | 05:55 PM
mickeypatches's Avatar
Car: 1984 camaro z28
Engine: 305 v8 h.o.
switched the headlight switch and the dimmer switch, and just replaced the lamp sockets and bulbs with leds and the warning lights with regular 194 lights. 3 of the gauge lights work and 3 of the warning lights work. if i move the cluster around it changes to 1 warning light and 2 gauge lights, i cant get more than 3 to work. my dad said it could be the printed circuit not making good contact, any ideas to what this could be?
Old Feb 29, 2012 | 06:57 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: some dash lights work
Your Dad is probably correct on his trouble shooting, if you look around you can find a new printed circuit. If you are really handy you can as I have repair yours with a rear window defroster repair kit.
Old Feb 29, 2012 | 07:07 PM
Engine: 305 v8 h.o.
yeah we thought it was the printed circuit before we replaced the lamp sockets. i can get a new printed circuit for $50-60 from classic industries. but how do you repair it with a rear window defroster kit. sounds alot cheaper and something to just try before we spend $50 on a new one
Old Feb 29, 2012 | 07:11 PM
Edwardgp's Avatar
Engine: 454-350
The kit comes with a liquid copper solution that when painted on a bad piece of circuit and allowed to dry it will complete said circuit.
Old Feb 29, 2012 | 07:13 PM
Engine: 305 v8 h.o.
wow. thanks hopefully this will fix it, can this just be found at advanced or autozone
Old Feb 29, 2012 | 07:16 PM
Edwardgp's Avatar
Engine: 454-350
Yes I have repaired a lot of circuits with this stuff, just take your time and keep everything clean.
Old Feb 29, 2012 | 07:17 PM
Engine: 305 v8 h.o.
alright thanks
Old Feb 29, 2012 | 07:27 PM
Engine: 305 v8 h.o.
im having a hard time finding it. any chance you could send me a link or tell me where you normally get it from. this would be greatly appreciated
Old Feb 29, 2012 | 08:29 PM
Edwardgp's Avatar
Engine: 454-350
I think the last one I bought was from Carquest but I would think any parts store should have it.
Old Feb 29, 2012 | 09:29 PM
Engine: 305 v8 h.o.
found the kit at advanced auto
http://shop.advanceautoparts.com/web...|GRP2034_____#
saving $40+ hopefully. picking it up tomorrow
Old Mar 1, 2012 | 07:13 AM
Edwardgp's Avatar
Engine: 454-350
That is the right one good luck on your repair, let me know if it works for you. Sometimes you will want to use more than one coat.
Old Mar 6, 2012 | 07:18 PM
Engine: 305 v8 h.o.
ok so i used the copper solution on it and basically used up the whole bottle, at first it only made 3 more lights work but then i twisted the lamp socket and i got all but 3 leds working and 1 running light. the 3 leds are all part of one circuit on the printed dash and the problem seems to be the printed dash is not making contact with the piece of metal that the printed circuit gets its power from on the car (sorry i have no idea what to call it) we tried pulling it and bending it out a little but it wants to go back to its original spot. we figured to stop there and work on it later. anyways product worked great and apply the instructions to the printed circuit. hopefully within a week all of my dash lights will be working
Old Mar 6, 2012 | 07:39 PM
Edwardgp's Avatar
Engine: 454-350
OK thanks for letting me know you had some success with this project, you can also use soulder and very fine flexible wire to bridge some gaps but always take you time and think it tlhru. Very low heat and very fine solder if you have an area that this will work for. Sorry having trouble spelling solder.
Old Mar 9, 2012 | 02:04 PM
90FirebirdTA's Avatar
Car: '90 Firebird
I am having the same problem..all of my warning lights work, SES, Seatbelt, etc. But the lights for the dash; speedometer, rpm and such dont light up anymore. I just need help figuring out if its the bulbs the printed circuit, or something else. Thanks
Old Mar 9, 2012 | 07:46 PM
Edwardgp's Avatar
Engine: 454-350
Well you will have to test the bulbs with an ohm meter or battery and if they are good something else is wrong.
Old Mar 13, 2012 | 11:37 AM
Car: '90 Firebird
ok. Now my left turn signal flasher is just a constant light now? when i turn my lights on it lights up and stays on and when i hit the switch for left turn it will flash on the inside but the outside signal light will not flash?
Old Mar 13, 2012 | 06:39 PM
Edwardgp's Avatar
Engine: 454-350
Usually something to do with a bad ground I believe. There are people on here that can tell you were to look on your car for these wires sorry but that is were my knowledge ends.
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
