AC positions and fan HI not working
Old Feb 29, 2012 | 08:47 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Ok, I'm having some issues with the AC panel:
HI on the fan switch isnt working (the rest are)...
AC compressor isnt kicking at all
When I move from Defrost to Vent (or where ever), the selector doesn't move the flaps at all...
Thoughts?
Old Mar 2, 2012 | 10:17 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
AC Anxiety
The hi speed is controlled by a relay.
To test the relay coil when it’s still in the car, apply 12 volts to pin D
orange wire.
If it’s good you will hear it ··CLICK··.
Also, if the rest of the relay and blower circuit is good, the blower will come on.
AC:
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the light green wire on the pressure cycling switch located on the accumulator (the silver can on the firewall).
Is there power there when the key is in the RUN position and the AC controls are set to AC?
Flap Trap:
The most likely cause of the blend doors not working is an interruption of vacuum to the Mode Selector.
You can remove the HVAC panel to see if the vac hose is still connected, if the vac hose pull air while the engine is running, and if not trace it back to the pinch or break.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Old Mar 2, 2012 | 11:03 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: AC Anxiety
Trace the larger power wire to your fan harness over the box along underneath the cowl. You'll find a connector near the center of the windshield cowl where it plugs into the engine harness. This connector will crumble apart in your hands as you fiddle with it. Cut it out and replace it with a heavy guage connector or splice. Your high speed fan will now work.
Old Mar 2, 2012 | 11:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: AC positions and fan HI not working
https://www.thirdgen.org/forums/elec...-resistor.html
JamesC
Old Mar 5, 2012 | 12:20 AM
zzjakect's Avatar
Car: 1985 Z28
Re: AC Anxiety
Your answer is incredibly correct!! I'm impressed and happy because it was simple, to-the-point and WORKED!
Thanks NAF
Jim J
Old Mar 5, 2012 | 12:22 PM
Car: 1988 Iroc-Z
I'll have to check that out this weekend... Thanks for the info fellas
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Leggman1
Aug 6, 2015 04:15 AM
