Deleting Vats, is there a better way?
Old Mar 3, 2012 | 04:07 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
I have a 1989 L-98 IROC that has been having Vats issues recently. From time to time the car won't start and the security light comes on. If I let it set for a little while then try the key again it will start. I'm assuming this is the chip on the key, either the reader is bad or the chip is worn out. I'd like to can this BS security system so I don't have these issues anymore. Is there a better way to delete it other than buying the VATS module and splicing it into the wiring harness? Can a performance chip be burned to delete this feature from the computer?
Old Mar 7, 2012 | 08:11 PM
Chris89FBForm's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI (For now?!?!)
Transmission: Auto-Stock
Axle/Gears: stock
Re: Deleting Vats, is there a better way?
Honestly the easiest way to do this is to test the resistance on the chip on the key, then go to Radio shack and buy resistors to match, splice into the wire that goes from ign. to Vats, and presto Vatts is overriden
Old Mar 7, 2012 | 09:29 PM
utilityguy2's Avatar
Or I can program it out for you. PM me if you want to go that route.
Old Mar 7, 2012 | 09:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Chris89FBForm
the easiest way to do this buy resistors to match,
splice into the wire and presto Vatts is overriden
Doesn't over ride VATS.
Only " fools " the module into "thinking" the correct key is being used ( a input to the module).
If fault is with the VATS module itself or wiring ( a output ) to the ECM then resistors will do zilch.
Deleting VATS in the tune ( prom) is the only way of completely bypassing VATS
Starter relay bypass required
Old Mar 8, 2012 | 05:49 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
its cheap enough to try this.i don't see the problem.it fixed mine.
Old Mar 8, 2012 | 06:20 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by zenish
i don't see the problem..
Problem is ;
some like the poster above don't understand how VATS works and believe the resistor bypasses VATS completely
It ONLY fixes the most common VATS fault ; the key being read incorrectly or not at all.
Plenty on here in the past saying ;" I did the resistor bypass but my car still won't fire up; why not? "
Edit
Another one today
https://www.thirdgen.org/forums/post...395-post1.html
Old Mar 8, 2012 | 08:03 PM
Old Apr 23, 2012 | 03:03 PM
TrAnSaMgTa1988's Avatar
Car: 88 Trans Am GTA 84 Camaro Z-28
Engine: L98 and a carbed 383
Transmission: auto but thats about to change
Axle/Gears: 4.11s
I have a 95 V6 3.4 and I just bought the Vatts bypass module... How do I know what wire is the fuel wire to splice into?
Old Apr 23, 2012 | 03:10 PM
Just curious, how much did you pay for that?
Old Apr 23, 2012 | 03:19 PM
Axle/Gears: 4.11s
here is a link. I found this one after I bought mine from Hawks Third Gen. I paid $59.99. I geuss I would go with the Hawks Third Gen one though just for their reputaion...
http://www.bakerelectronix.com/products_vats/
Old Apr 23, 2012 | 03:53 PM
Seems like a reasonable price. Really not much to it but a resistor and LED and a diode. a couple bucks in parts but if it's easy to install, may be way to go for many people. I prefer to program it out myself. Thanks for the info.
Old Apr 23, 2012 | 08:55 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I bypassed the key on my iroc and still had a problem with it not cranking sometimes so just adding a resistor doesnt cure the problem sometimes. I ended up cutting the starter wire(yellow wire) in the ignition harness under the steering column and ran a new wire from it(column side) straight to the starter solinoid. Cranks and starts everytime now and havent had a problem since. My vats module is still working and turning on the fuel pump and injectors or whatever it turns on but the key is bypassed and the starter enable relay is bypassed. Dont have to rely on those parts now for cranking.
Old May 9, 2012 | 12:03 PM
Bryan Thacker's Avatar
whats the wire from ign. to vats??1991 camaro rs 3.1L
RS Reaper
Oct 17, 2018 07:52 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
