What wire for Parking light flash for a alarm system
Old 03-04-2012, 03:49 PM
86Stevo's Avatar
Ok so I'm putting a alarm system in my car but I can't find what wire to connect to for te parking lights to flash I saw online brown and there were two dark brown almost black wires so I connected it to that on the headlight switch that pulls out and nothing so of some could fill me in that would be awesome I have a 86 camaro z28
Old 03-04-2012, 09:08 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: What wire for Parking light flash for a alarm system
It should be a brown wire at the headlight switch. Use a volt meter to see if you tap into the correct wire. Should show 12 volts at the switch when in the parking light position.
Old 03-07-2012, 10:06 AM
86Stevo's Avatar
I tried that but I have like 5 wires that have 12v in the parking light position there was no brown there was a thick black wire that assumed was ground and then there were two smaller dulled out grey wires going into one connection witch is what I tapped off of and the. A red yellow and I think a green it was like Christmas in there except with out that missing brown wire that I need to find :/
tnrednneck
08-13-2015 08:57 AM
Omega
08-10-2015 12:46 PM
NBrehm
Exterior Parts for Sale
08-05-2015 08:19 PM
Quick Reply: What wire for Parking light flash for a alarm system
