lol I give up
Old Mar 7, 2012 | 06:30 PM
Chris89FBForm's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI (For now?!?!)
Transmission: Auto-Stock
Axle/Gears: stock
lol I give up
So, I just finished replacing the last part of the long checklist, the EGR Valve. Unless you are familiar with my posts, my 89 305 TBI has had some crazy activity.
In short, she runs sound until she is warm then all hell breaks lose and she goes bat **** crazy, She dumps fuel in like she is thirsty, stops pumping fuel whenever. SES light flashes, stays steady, or none at all. There is no onset of these problems other than it being warm or hell today was 50ish deg. and it started doing it right away.
I've replaced the entire Dizzy with brand new cap n rotor,
new coil pack
new sparkplugs (not fouled),
new wires
new ESTC (electronic spark timing control mod)
new MAP
new EGR valve
new CTS
new O2 sensor
new knock sensor
new TPS
new Injectors
new injector harness
new TB seals
New vacuum line
pretty much you get the idea. I have 1 last thing to replace and that is the ECM, any chance that it may not impact the problem? I've taken it to get the SES codes pulled and none are stored, I can never get it to have a light when I go to test it.
Also it doesn't seem to have any grounding out, and I cleaned all the plugs and checked for crack wiring throughout the entire engine.
Old Mar 7, 2012 | 09:35 PM
utilityguy2's Avatar
Re: lol I give up
Sounds like it is going into limp home mode which may indicate a processor failure. Make sure the prom is plugged in tight and not partially out. Make sure the connectors to the ECM are secure. The ECM could be bad. About $25 at u pull it salvage yards or online around $50. If you get a different ECM remember to put your old prom and netres into the new one as they are all different. You may not get a ECM that was from your car originally as they were used in lots of things.
Old Mar 7, 2012 | 10:02 PM
Axle/Gears: stock
Re: lol I give up
Question, where is the Prom located, I know where the ECM is, and I plan on buying a reman'd one, I just hate the rat's nest of wiring I have
Old Mar 7, 2012 | 11:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: lol I give up
Originally Posted by Chris89FBForm
the ECM,
In or out of car ?
Old Mar 8, 2012 | 02:11 AM
Re: lol I give up
The blue thing in above picture.
Old Sep 17, 2012 | 03:46 PM
amyz28's Avatar
Re: lol I give up
geez sounds similar to mine im buying new ecm this week is the blue thing in ur pic the prom? heres my post
hey i was wondering if u cud help, my ses light goes goes crazy whilst during a normal start up AND when connecting A and B in ALDL port and as lights flickering (as tho theres a bad wire)the engine drops revs, does this mean its ecm problem or electrical, my car 86 iroc TPI 5.0 has been 'broke' for 1 WHOLE YEAR NOW and its killin me im over in scotland and no want wants to work on her plz help heres a vid
p.s ive changes plugs, leads, 02 sensor, coolant temp sensor and thermostat, new battery.car ran perfect till it was out for a hard drive (which wasnt common) my gut feeling is its electrical i cant get any codes
this second vid is with the A AND B bridged, it wont read a code
http://www.youtube.com/watch?v=InNYu...3&feature=plcp
86White_T/A305
Mar 6, 2016 01:48 PM
luvofjah
Sep 26, 2015 08:28 PM
RedLeader289
Sep 23, 2015 06:50 AM
morrow
Fabrication
Sep 14, 2015 09:01 PM
earlpote
Sep 12, 2015 11:55 AM
