Vats with no computer?
Old Mar 7, 2012 | 06:31 PM
formula_355's Avatar
I have an 89 formula with a 383 about to be put in it. Its carbureated so I removed the computer and its wiring. Will I have to do anything to get the vats system to let me start it?
Old Mar 7, 2012 | 06:36 PM
Chris89FBForm's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI (For now?!?!)
Transmission: Auto-Stock
Axle/Gears: stock
Re: Vats with no computer?
without the ECM the vats will have no purpose, therefore not hinder your drivability.
Old Mar 7, 2012 | 06:48 PM
So I won't need to do anything to get it to start?
Old Mar 7, 2012 | 06:56 PM
Axle/Gears: stock
Naw, what happens is the VATS module checks for resistance in the key, and sends that info to the ECM. Without the ECM the VATS just checks resistance in the key, it may be a good idea to unplug it, but even if you left it plugged in. it has little to nothing to do with teh actual ignition process, what happens is the ECM doesnt get a response from VATS saying good to go and it goes into shut down mode in about 5 seconds.
Old Mar 7, 2012 | 07:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
What about the starter interrupt relay controlled by VATS?
Old Mar 7, 2012 | 08:30 PM
Axle/Gears: stock
My Vats was not reading any key period, and I could start it just fine, just died in ~5 seconds. any starter Int. relay can be bypassed relatively easy.
Old Mar 7, 2012 | 08:57 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Exactly ;
but you FORGOT to mention that little fact when you stated
"the vats will have no purpose"
OP could be forgiven for thinking's his engine will start straight up if he removes the VATS module
My Vats was not reading any key period I could start it just fine,,
So the relay was obviously bypassed
Rather pointless then
Old Mar 7, 2012 | 09:04 PM
I'm not planning on removing the vats module, but i just removed the computer and its wiring to the engine bay. I know the vats sends a signal to the computer to cut off injectors, but i shouldn't have to worry about that since i'm carburated. The only part i'm worried about is the starter interrupt relay, and if thats affected by the removal of the computer at all.
Old Mar 7, 2012 | 09:28 PM
utilityguy2's Avatar
As long as you leave the starter interrupt relay and wiring alone. and don't remove the vats module, and the key and ignition is OK then it should engage the starter.
Old Mar 7, 2012 | 09:40 PM
thanks for the quick replies guys! And glad to have a fellow Minnesotan help me out utilityguy2!
Old Mar 7, 2012 | 11:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
However
given the problems VATS presents with age ( several times a week on here guys seeking to remove it because it is giving problems )
and the fact that it is now doing nothing for theft protection now you have a carb ( starter easily hotwired )
I would suggest doing the starter bypass to eliminate VATS completely from future problems and install a hidden kill switch for the ignition or fuel pump ( if using elec pump )
RS Reaper
Oct 17, 2018 07:52 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
