Check engine light not coming on.
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
My check engine light just stopped working. No light light when I loop a and b to set timing.
Any thoughts?
Any thoughts?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Check engine light not coming on.
First off you need to disconnect the est and set the timing not jumper a to b to go into diagnostic mode. you can check the ses bulb or with the engine running you should have power on pin a5 brn/wht at your ecm
Engine: 5.7 TPI
already disconnected the est and timed it, all the manuals say to jump a to b on the adal or what ever. This car is smog equip.
Engine: Lb9
Transmission: M20
Engine: 5.7 TPI
read the manual. It says to jump a to b disconnect the est, set timing, pull jumper a to b, shut off car. reconnect est, disconnect neg batt for 30 seconds. to reset any codes.
Not that complicated. Still no check engine light.
Engine: Lb9
Transmission: M20
check you fuse , you check engine light bulb and than if thats ok and you have power at pin a5 of the ecm with the engine running than bad ecm. not that hard
