wires that i cant find a conection to 89 trans am gta 5.7
Old Mar 20, 2012 | 01:02 PM
emanortiz's Avatar
ok thers a wire that comes out from where the 02 sensor cable cover is there is just one little wire with a connection but i dont know where it conects to and also theres another wire just hagging from where the starter is near there theres a sensor on the block and there another wire there witch i cant find connections to what happend was my head gaskets blow so they rebuilt my engine and ever since i got it back the car start fine the first time when its cold and runs strong but then when it worm up and i turn it off and try to start it up again it just cranks but wont start after 40 min when it cool off it will start up again plz help i love this car and i dont want to get rid of it
Old Mar 20, 2012 | 05:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: wires that i cant find a conection to 89 trans am gta 5.7
Originally Posted by emanortiz
thers a wire ......
there is just one little wire with a connection .....
also theres another wire just hagging .......
Color of wires in question would help.
Old Mar 20, 2012 | 05:58 PM
zombienerd's Avatar
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
No idea about the loose wires, but your warm start problem sounds a heck of a lot like Vapor Lock. After you turn off your engine, the heat actually rises more for 10-15 minutes. This heat can vaporize the fuel in the lines and lock the line until the temperature lowers enough to re-condense.
You can alleviate this by thermally wrapping any exposed fuel lines, replacing any missing/holey heat shields over the manifolds, etc.
For the wires, as the poster above me said, we need wire colors...
camaro11j
Sep 19, 2018 08:49 AM
The_Phoenix
Feb 4, 2016 07:10 AM
jharrison5
Aug 19, 2015 05:53 PM
gta power
Aug 13, 2015 06:15 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
