strange flashing lights
Old Mar 21, 2012 | 09:24 PM
SanAntonio3's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 1994-1995 LT1 5.7
lately I've been having a flashing lights issue. I drove the car home from school... about 15 miles... at about the 10th mile on the freeway my headlights started flashing and didn't stop. I pulled over and turned the car off, turned it on and it was fine for about a quarter mile then it started again. Got home and it kept doing it. Cycled the headlight switch on and off. Still nothing. Voltage gauge reads 14
Old Mar 24, 2012 | 04:45 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: strange flashing lights
the head light switch has a circuit breaker inside of it. if the headlights pull too much current, the circuit breaker gets hot and opens up then cools off and closes causing the symptoms you describe.
someone could have replaced the headlight fuse in the fuse box with a circuit breaker.
extra lights such as fog or driving lights wired into the headlight wiring can cause too great of a current draw.
also, old age can cause a circuit breaker to open at a lower current than it should.
Hellbillydeluxe
Sep 22, 2015 09:58 PM
red90IROCls1
Aug 25, 2015 06:56 AM
justin57
Aug 20, 2015 07:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
Omega
Aug 10, 2015 12:46 PM
