Dash lights/parking lights/fog lights wont come on when switched BUT.......
Old Mar 23, 2012 | 08:16 PM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
Hello all,
I got a frustrating problem with my 87 bird.
one day last fall just before i was about to store it for winter the dash lights, fog lights, parking lights stopped working all a sudden. The headlights work, however only one light will pop up and they dont go down. The interior lights work when the doors are open, brake lights work. Turn signals work fine. Car has standard dash.
I have replaced the main headlight switch in the dash but that did nothing. All fuses are good.
Now the weirdest thing about all this is that i have a viper alarm on the car. When i arm/disarm the alarm all the lights dash/fog/parking all work fine! Am i looking at a problem with relays/fuses or wires or could this possibly be the fault of the alarm since all lights work when alarm arms/disarms.
I really want to be able to drive at night!!! this sucks!
Any help is appreciated.
-87_gta
Old Mar 26, 2012 | 03:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Alarm & Disarm
The unknown here is the wiring of the alarm.
The splices could be of poor quality therefore has caused this problem.
Put the lightswitch in the “park” position.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the brown wire at the switch.
Is there power there?
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Old Mar 30, 2012 | 02:16 PM
87_gta's Avatar
Axle/Gears: Stock
Re: Dash lights/parking lights/fog lights wont come on when switched BUT.......
I have no voltage at the brown wire. There is an orange wire soldered to the brown. The connection seems good.
I do have power at the red wire. I have replaced the headlight switch.
Old Apr 2, 2012 | 04:19 PM
NINÅ's Avatar
Transmission: 765R4
Alarm & Disarm
Probe the orange wire with a black stripe.
There needs to be power there regardless of the switch position.
Is there?
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Apr 3, 2012 | 08:09 PM
87_gta's Avatar
Axle/Gears: Stock
Ok so on my headlight switch i do not see an orange wire with brown stripe.
the wires and voltages i do see are as follows
-Solid Orange: switch off 0.15v. On 0v
-Space: with switch on i get power here but no wire going in. 11.97v
-Red: (main power??), switch off 11.96v. On 11.97
-Yellow: switch off 0. On 11.5v
-Brown: switch off 0. On 0. Should this one have voltage? This wire has another wire soldered on, connection looks good.
-White: switch off 0.15v. On 0
I have also replaced the remote dimmer switch with no change.
Old Apr 4, 2012 | 04:21 PM
NINÅ's Avatar
Transmission: 765R4
Alarm & Disarm
Hopefully the PO didn’t rewire or change wire colors.
You are supposed to have power on the
brown wire when the switch is in the “parking lights” or headlight position.
The unused terminal “
Space” is operating like the “parking lights” circuit is supposed to.
You might be able to connect the
brown wire to that terminal.
Use a fuse for protection.
Happy Racing!
Old Apr 5, 2012 | 12:15 PM
87_gta's Avatar
Axle/Gears: Stock
I just probed the brown wire again but this time i was arming/disarming the alarm.
When i did this i would get a voltage when the lights flashed. I probed the wire right on the metal part of the switch.
I have 2 headlight switches. One of them brand new. I get the same reading on both.
I used a continuity tester on both switches that i have, when i probe the main power terminal and the terminal where the brown wire is suppose to be i get no reading.
When i probed the power and the "space" its good. Same on both switches. This leads me the think the switches are the problem. When i probe the brown wire i get a reading if i arm/disarm the alarm.
ideas?
thanks!
Old Apr 5, 2012 | 03:50 PM
NINÅ's Avatar
Transmission: 765R4
Alarm & Disarm
That’s normal, and no further ideas besides using the “
Space” terminal for the “parking lights” circuit.
Happy Racing!
Old Apr 5, 2012 | 07:29 PM
87_gta's Avatar
Axle/Gears: Stock
I moved the wire to where the space is and the parking lights do work but they are always on. Power stays at the space even with the switch off .
This is so frustrating. is there anything with the switch itself that could be causing this?
Old Apr 9, 2012 | 03:41 PM
NINÅ's Avatar
Transmission: 765R4
Alarm & Disarm
In post #5 you wrote “Space: with switch on i get power here”.
If that was a mistake, obviously you can’t use it.
The odds of getting a new switch with the same problem as the old one is extremely low.
What is the part number and make of the new switch?
Happy Racing!
If My Engine Has An Illegal Part, And The Inspector Doesn’t Hear It, Does It Make A Sound?
Old Apr 10, 2012 | 12:29 PM
87_gta's Avatar
Axle/Gears: Stock
I got the new switch from the dealer. Part # 717-11276
Original switch is delco-remy. Part# 204-78X (part number is faded)
When i probe both to see how the parking light circuit worked i found that the Solid Orange wire is the one that connects to the Brown wire.
I traced the Solid Orange wire to just above the fuse panel and found a bad connection. Fixed that up and now EVERYTHING WORKS!!
Thanks for the Help!
87_gta
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
stalkier
Aug 21, 2015 01:54 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
