can't find answer for turn signal problem. FIXED!
Old Mar 25, 2012 | 09:03 PM
Lippard9202's Avatar
Car: 1986 Iroc
Transmission: 7004r :(
my problem started the night when I put my column back together from tightening it, (was wobbly). now, when I click it to the left side, the FRONT left side illuminates, but stays solid, also the LEFT flasher indicator in the dash doesnt illuminate when the turn signal lever is in the down pos., or when the hazards are on. the right signal does the same thing, just flashes on, and stays on. but the interior indicator lights up.when I engage the hazards though, the FRONT signals flash normally! the rear turn signals do NOTHING. they dont flash for left, right, or even the 4-ways. I replaced the rear bulbs. nothing. I replaced the flasher under and to the right side of the column. still nothing. while I was replacing the flasher unit however, the lights DID flash a couple times. but I couldnt get it to repeat that. all of the features regarding flashing indicators DID WORK on the day (before) I tightened the loose column. what would you guys suggest? THANKS in advance, and i apologize for being nooby... haha
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
