Fuse Blown
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Fuse Blown
So when ever i use my unlock and lock i hear a pop and i blow a fuse..... i put in the engine myself.. .and i didnt ground many things... lazzy me.. coudent find a grounding place.. is this the reason?
Car: 88 Camaro
Engine: 350 .030 over, carbureted
Transmission: T-5 w/Centerforce clutch
Axle/Gears: Haven't checked yet!!!
Re: Fuse Blown
also anything that should be grounded....SHOULD BE GROUNDED!!!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
You’re Grounded !
We assume it’s the ACC fuse that is blowing because you failed to state.
Disconnect the left lock motor, then operate the locks.
Does the fuse still blow?
Now reconnect the left lock and disconnect the right lock motor, then operate the locks.
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Happy Racing!
Transmission: 765R4
You’re Grounded !
You can disconnect at the relay located behind the left shroud.
You should see two tan wires at the relay.
Disconnect one at a time.
It’s not necessary at this time to know which is the left or right.
Happy Racing!
Happy Racing!
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
