pass key decoder moduel location???? Please Help
Old Apr 4, 2012 | 03:42 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
Axle/Gears: G92 3:23
hey guys im looking for a write up for the pass key decoder moduel or step by step how to replace it?? thanks
Old Apr 4, 2012 | 03:47 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: pass key decoder moduel location???? Please Help
I do remember seeing one in my factory sevice manual.
Old Apr 4, 2012 | 03:50 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Must be a bad day for this, mine wouldn't start this morning. Got it hauled home and it just started right up. Scared of it now. But the module on my 89 was up high in the dash hidden in front of a heater duct. Can't hardly even see it. About the size of a pack of smokes.
Old Apr 4, 2012 | 03:58 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
there's gotta be something out there im sure im not the only one that has done this before
Old Apr 5, 2012 | 12:38 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
where can i find the location of the pass key decoder module? anyone have pics of the location plz thanks
Old Apr 5, 2012 | 12:42 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It's located behind the defrost vent(duct) area
Old Apr 5, 2012 | 12:55 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
so im guessing the dash pad comes off ? you have pics of the location i cannot find it lol i must be blind
Old Apr 5, 2012 | 03:40 PM
TTOP350's Avatar
Not just the pad. The whole dash. Enjoy.
Old Apr 5, 2012 | 04:11 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
r u for reals dang , alright sweet i better get started lol.thank you
Old Apr 5, 2012 | 04:55 PM
Engine: Lb9
Transmission: M20
it's easier just to reprogram the eprom in the memcal. lol
Old Apr 5, 2012 | 08:33 PM
gp90gta's Avatar
Car: 1990 GTA
I was once asked how to bypass this without doing a prom, when I looked at the diagram I was like heck ground three wire on the module and its over with, so the next day I go out to test my theory, get under the dash and start looking for the module, well I couldn't find it so I jump on here and do a search to see where it is, WELL gm must have known that if someone looked at the diagram they wold see how easy it would be to get around it, so they put that sucker up where it would take forever to get to, so I would agree with Tuned on this one just get a new prom with VATS turned off and save yourself the headache of all that work.
Old Apr 15, 2012 | 07:37 PM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
Originally Posted by gp90gta
I was once asked how to bypass this without doing a prom, when I looked at the diagram I was like heck ground three wire on the module and its over with...
gp90gta.. ive got my passkey module out now, and dont have the time or money to waste on the prom burning. i would like to test your theory. which three wires need to be grounded in order to send the proper signal to the ecm?
To answer the origional question, your first step will be to stop at the gas station and buy a case of beer. the next thing you'll want to do is reschedule any plans you had for the weekend because your in for a fun project! its not too difficult, but extremely time consuming. in order to get to the passkey module it requires dropping the entire dash... dash pad, steering column,guages and the part of the console the radio and heater controls go in. after dropping the dash, pull the defroster ducting back and you should see it bolted to the backside (firewall side) of the passenger defrost duct. you cant miss it, has a sticker on it that says passkey.
Old Apr 15, 2012 | 08:39 PM
gp90gta's Avatar
Car: 1990 GTA
Looks like if you ground A2,A3 and A4 it should be completely bypassed, but just to make sure its a good idea to check GF10 at the ecu to make sure its grounded with the VATS module working.
Old Apr 19, 2012 | 12:43 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
i found the module not bad i was expecting worse i got new module inn and the security lights off finally and clear the code 46, car still doesnt crank??? i apply ground to the purple wire going to the starter and it cranks wonder whats the problem
Old Apr 19, 2012 | 01:35 PM
gp90gta's Avatar
Car: 1990 GTA
Check battery, check all fuses, if good, ignition on check for power and ground at the starter relay, if it has power and ground put the key in cranking position and check power to starter.
Old Apr 19, 2012 | 06:00 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
hey gp90gta i checked all the fuses they are all fine im only getting 0.6 v at the yellow from the ignition switch and the starter relay i know it should be 12v
Old Apr 19, 2012 | 06:02 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
its got new ignition switch, new starter relay,computer and new theft deterent module
Old Apr 20, 2012 | 11:23 AM
gp90gta's Avatar
Car: 1990 GTA
The starter circuit, 12v side, battery to fuse box, fuse box to ignition switch, ignition switch to starter relay, relay to neutral safety switch, neutral safety switch to starter.
69 Six Pack
Oct 5, 2015 07:51 PM
WIzmo
Aug 30, 2015 02:30 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
