What are these engine electronic parts?
Old Apr 5, 2012 | 04:18 PM
tommytank's Avatar
So I need to do the electrics. Does any third gen genius know what these are for? Starting with this:
which is connected to this:
Next up, what are these for:
Which sit...
...here. The loom wraps across the back of the engine, down the side of the O/S wind and into the car.
Is this a Speedo drive?
What is this for?:
...and what does this connect to, which comes from the previous box?
...same with this?
Any help greatly appreciated! Bit hard to get tech assistance in the UK for niggles like these!
Old Apr 5, 2012 | 05:34 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: What are these engine electronic parts?
Taking guesses in order of the pictures posted.
1) Appears to be the A/C clutch plug (two terminal, '87-older V-belt compressor) which, for some unknown reason, is tied to the either the plug for the knock sensor or, fan temp switch. I'd guess fan switch, someoneone removed the A/C, tied those together to try an make the fan work. THe green wire is A/C input to the the ECM, it wouldn't have worked anyways.
2) Same as 1
3) The flat box is your ESC (spark control module). Considering the mess, the others are either MAF relays, fuel pump or, fan (depends on wire colours on the plugs).
4) Wow, I though I had a wiring mess.
5) Looks like the plug for the A/C pressure switch (light blue and light green wires). Goes to the silver can that is on your blower box (if it's still even there)
6) Guessing from the heavy purple wire, high speed blower relay
7) Purple, +!2v to blower, black, ground for blower
8) Plug for the (probably non existent) resistor pack on the blower box, it's for the other three fan speeds that aren't the fastest (hi)
What do I win if I guessed any right ??
Old Apr 6, 2012 | 02:42 AM
tommytank's Avatar
Deadbird! You legend! Thanks so much for taking the time to go through that. As far as I can see then: As my car is running a carb, there is no a/c because I live in Scotland, and (well guessed) my total lack of blower which I will go aftermarket with, the only thing I need to keep is the spark module. No spark at present so that explains a lot.
You win a cuddle but you need to come over here to get it!
Old Apr 6, 2012 | 12:04 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
advice on wiring? $10. how much it's gonna cost to fix everything? a lot of $$$. offering to pay the guy who helped you get it all started with a cuddle? priceless
Old Apr 6, 2012 | 06:20 PM
deadbird's Avatar
Engine: TPI 305/ v6
Originally Posted by tommytank
Bit hard to get tech assistance in the UK....
I sure do hope that's a brand of beer over there
Old Apr 13, 2012 | 04:16 AM
tommytank's Avatar
Its sadly not. Everyone needs a cuddle from time to time!!
So i am now running an HEI distributer and rochester carb. Assuming that the heater and aircon are removed, is it safe to say all the circuits up there are pretty much redundant now?
italiano67
Dec 11, 2016 09:21 AM
Fast355
Dec 2, 2016 06:33 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
