Illuminated toggle switch
Car: 84 Z28 T-Top
Engine: L69
I already have a vacuum switch which controls my TCC, I also have a lighted toggle switch to turn the thing off. Is there anyway to wire the lighted switch to light ONLY when the vacuum switch activates the system? It's a 3 prong, single pole switch.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Switching Subjects
That depends the way the manufacturer made the switch.
Some are internally wired, sometimes with a diode also, which limits it to light on when the switch is in the ON position, therefore cannot be used as an indicator.
Do you know the brand and part number of the switch?
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Happy Racing!
Transmission: 765R4
Switching Subjects
Yes that appears to be the type which has the bulb internally wired so you can’t use it as an indicator.
You need a switch with an isolated bulb or LED.
One of them is the NKK M2123LFG01.
Happy Racing!
Happy Racing!
Randomtask2
Sep 10, 2015 08:37 AM
