Where is the Battery Sign/Alt Sign in the dash? I need to replace the light.
Old Apr 8, 2012 | 02:19 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Where is the Battery Sign/Alt Sign in the dash? I need to replace the light. My alternator and battery are both new, and the wiring is good between the alt and the batt, but it’s not charging. Before I spend the $50 to go get the full electrical diagnostic, I want to replace this light bulb to see if that will fix it (has been suggested by several people and a professional auto mechanic). But since it has never lit up, I don’t know where it is behind the dash. Any help?
Old Apr 8, 2012 | 02:49 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: Where is the Battery Sign/Alt Sign in the dash? I need to replace the light.
I have never heard of the dummy light causing your alternator to not charge. What does your gauge say? Have you tested the alternator? Auto zone does it for free. I have had a few brand new alternators NOT work right from the box.
Did you check the big fuses under the hood?
Old Apr 8, 2012 | 03:11 PM
Car: 1992 Camaro RS
Battery: Good, Alternator: Good, Fuzes: All Good, Wiring from Alt to batt: Good, Light: Unknown.
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
