Alt wiring help please
Old Apr 11, 2012 | 12:09 AM
fbodyluver's Avatar
putting a TPI in an old chevy truck using the serpintine system and accys
I need to know where to run the wires from the pigtail on top of the alternator (red, black and brown). I will be running a volt meter as a gauge not an amp meter.
Old Apr 11, 2012 | 06:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Alt wiring help please
Old Apr 11, 2012 | 06:39 PM
fbodyluver's Avatar
Originally Posted by tunedperformanc
Thanks for the info,that looks easy enough,
do I still need to use the brown wire if I am not using a warning lamp? I will be running a autometer volt gauge
Old Apr 11, 2012 | 07:59 PM
Engine: Lb9
Transmission: M20
no you can just attach the sense and the output post
Old Apr 11, 2012 | 11:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
unless Alt has been rewired as a 1 wire " self exciting " unit
you need the L terminal connected to a resistor or lamp ( which acts as a resistance) to supply the signal to excite the Alt
See
http://www.alternatorparts.com/cs130_sbpage2.htm
http://www.alternatorparts.com/cs130_sbpage3.htm
Old Apr 12, 2012 | 09:18 AM
fbodyluver's Avatar
See
Good information but the only thing not mentioned is what kind of resistor do I need to use? Someone mentioned a 5 watt but what is the resistance value?
does anyone have a source or a part number for the reisitor?
Old Apr 12, 2012 | 11:57 AM
Engine: Lb9
Transmission: M20
Old Apr 12, 2012 | 12:03 PM
Engine: Lb9
Transmission: M20
looks like gm recommends 50 ohms inline if you install it in the engine compartment solder it in and use shrink tubing over it.
Old Apr 12, 2012 | 01:13 PM
fbodyluver's Avatar
Thanks for the help guys! That answers my questions
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
