Battery Drains overnight and dies
Old Apr 13, 2012 | 08:25 AM
davidjr74's Avatar
Car: 1985 Camaro Iroc
Engine: 350 tpi
Okay I have been having this issue for a weeks now.
So far I have replaced Battery, Alternator, and both terminals. Also the inline fuses with these wires I replaced with a circuit breaker.
Here's what happens when I drive....if I am hitting around 20mph my volts usually stay at 13. However, as soon as I brake and start slowing down (especially at red lights) my voltage drops to the 8-9 area and my car struggles to stay alive until I hit the gas again.
Old Apr 16, 2012 | 03:56 PM
davidjr74's Avatar
Engine: 350 tpi
Re: Battery Drains overnight and dies
Have not figured it out yet. For the time being i have been taking out my negative battery cable to get by.
Old Apr 16, 2012 | 05:12 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
What I have done for this kind of thing is get a buddy to hold a meter to measure amp draw between the positve cable (disconnected) and the battery positive terminal. Then I pull fuses until the draw goes away on the meter. Then I at least know what circuit is the problem.
Old Apr 16, 2012 | 06:52 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Check your alternator charge wire and battery cables for corrosion. They corrode from the inside so it is hard to see. Try bending the wires and make sure they are flexible and don't make cracking noises. And make sure all the connections between battery, alternator, and ground are all tight and corrosion free.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
85cmroz28
Oct 4, 2015 09:44 PM
89 formula TPI
Sep 7, 2015 11:06 AM
