Convenience center
Old Apr 13, 2012 | 10:07 AM
Ian Irvine's Avatar
Convenience center
The metal frame that holds the convenience center in my 84 is held in with two sheet metal screws that attach to the front of the dash. There is no support at the back of the metal frame. It seems to me that this assembly is too heavy to be secured by only two screws and only in the front. I know that a previous owner has had the dash out so I am wondering if a support bracket is missing. Any ideas?
Old Apr 13, 2012 | 02:53 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Convenience center
There should be two "lever" like arms on either side of the convenience center.
You squeeze these arms towards the center of the convenience center and pull it down. It's hinged on either the front or rear edge (I forget which).
Old Apr 13, 2012 | 03:58 PM
Ian Irvine's Avatar
Hi Paulo:
Thanks but I'm asking what secures the metal housing that the "pull down" plastic part fits into. My car is anything but stock and at idle I had a vibration in the dash right in front of the driver. This unit isn't well secured and I think that it may be rattling around under there. I can fabricate something but if there is a stock bracket missing then I'd rather go that route. So that I'm clear, the metal housing is secured at the front with sheet metal screws...there is nothing securing the back. Can I ask what you have in your car?
Ian
Old Apr 13, 2012 | 09:34 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
My bad. It's the fuse block that swings down. It's been a while since I've been under the dash.
To correctly answer your question, there is a brace for the Convenience Center according to the '86MY assembly manual. Of course, it may have been deleted in actual production.
See attached.
Old Apr 14, 2012 | 09:35 AM
Ian Irvine's Avatar
Hi Paulo:
Fantastic...that answers my question. Thanks kindly. Is that assembly manual a download? If yes, a link would be appreciated..Ian
Old Apr 15, 2012 | 04:00 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Not a download. It's a pdf from a hard copy page.
Old Apr 15, 2012 | 09:24 AM
Ian Irvine's Avatar
OK...thanks again
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Eric-86sc
Sep 28, 2015 11:37 AM
