Temp gauge reading high
Old Apr 16, 2012 | 12:20 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I think my temp gauge is reading high
I found this thread while searching
https://www.thirdgen.org/forums/elec...ding-high.html
and this chart
https://www.thirdgen.org/forums/atta...ase-ctsmat.gif
I just wanted to double check. I set my pot to 55.1 ohms and the needle pointed straight right off the scale. I just wanted to double check these values are correct for a 1984 l69 trans am.
Also can it be fixed?
Old Apr 18, 2012 | 12:38 PM
midias's Avatar
Re: Temp gauge reading high
Looks like it might be reading 20ish degrees high. Anyone have any ideas on a fix?
Old Apr 24, 2012 | 08:41 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
You can put a resistor in series with your test resistors to see if that causes the gage to read accurately at both ranges.
If the above does not cure the problem replace the gage.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Ghettobird52
Jul 5, 2024 11:18 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
