Mechanical to Electronic Speedo
Old Apr 16, 2012 | 09:13 PM
crazboy's Avatar
Hey guys, I've got a question.
I have a mechanical transmission, and I drpped it into a 1986 Trans-Am.
Problem is that the speedometer is electronic. Now, I have tried to put in a pulse generatorm but, unfortunately, the calibration isnt correct, I'm showing much greater speeds than what I am actually doing.
Anyone know where I can get the proper pulse generator for this?
Thanks all.
Chris
Old Apr 17, 2012 | 01:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Mechanical to Electronic Speedo
Assuming you have a stock type VSS generating the signal ( the correct one for your year engine; there are 2 types with different signals )
you need to change the gears that drive the VSS in order to calibrate it correctly.
http://sethirdgen.org/vss.htm
Certain gear combos suit certain diff/ tire setups
Old Apr 25, 2012 | 05:14 AM
crazboy's Avatar
Ill look into this .. thank you.
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
sjorgens
Oct 1, 2015 07:54 PM
anesthes
Sep 30, 2015 07:48 AM
mfp189
Sep 27, 2015 09:25 AM
