speedo
Old Apr 26, 2012 | 04:57 PM
q man's Avatar
Car: 87 ta
Engine: 350 zz4
Axle/Gears: 4-11
speedo
I have a 87 T/A that I swapped motors, I put in a zz4 with a 4-11 rear. My problem is that the mileage meter doesn't work and the speedo is way off but the tach works fine, the speedo doesn't have a cable its electronic can anyone help, I live in southern maryland
Old Apr 26, 2012 | 05:05 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: speedo
You change the gear in the tail shaft of the tyranny?
Old Apr 28, 2012 | 05:44 AM
q man's Avatar
Car: 87 ta
Engine: 350 zz4
Axle/Gears: 4-11
Re: speedo
no i dont think so i didnt change the motor and rear
Old Apr 28, 2012 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo
Confusing. If you swapped in 4.11's and didn't change the drive and/or driven gears in the trans, the speedo wouldn't read correctly.
JamesC
Old Apr 29, 2012 | 10:04 AM
q man's Avatar
Car: 87 ta
Engine: 350 zz4
Axle/Gears: 4-11
Re: speedo
so your saying that i need to change a gear in the tranny i had someone do the work for me im not sure what they did
Old Apr 29, 2012 | 10:16 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Re: speedo
Yes due to the 4:11 gears being higher than your stock gears which were probably 3:42. The gears in tuft's tail shaft of the transmission need to be changed to match the new ratio.
Old Apr 29, 2012 | 05:59 PM
q man's Avatar
Car: 87 ta
Engine: 350 zz4
Axle/Gears: 4-11
Re: speedo
Thanks do I have to drop the tranny or just pull the driveshaft and where can I find that gear
Old Apr 29, 2012 | 06:44 PM
JamesC's Avatar
Re: speedo
Here's the idea:
http://sethirdgen.org/vss.htm
The part 'might' be available below:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old May 4, 2012 | 07:32 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Re: speedo
You shouldn't have to pull the driveshaft or tyranny. The device is a 10mm bolt on the drivers side of the tranny tailshaft. Pull the CSS and take that gets off and put the new one on. Replace the vss back into the tyranny and bolt it down. Hook everything back up and test drive brother
Old May 4, 2012 | 07:48 AM
JamesC's Avatar
Re: speedo
If the OP has to swap out the drive gear, he'd have to drop the DS and tail shaft.
JamesC
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
