1987 IROC Slew of Issues. Any help appreciated.
Old May 1, 2012 | 01:44 AM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
Just got my car to run today for the first time in 12 years. My problem is that it will start when the key is turned all the way to start, but dies when the key is turned away from the start position. The alternator is dead, and removed from the car if that helps. I tried putting it back in just to try to complete the circuit but that didnt work. But maybe its so far gone that theres something wrong internally. Any insight?
Old May 1, 2012 | 01:58 AM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Re: car wont run when key is not turned to start.
does it grind when you leave the turn key on? and at what revs?
Old May 1, 2012 | 02:00 AM
pvr007's Avatar
Engine: 305 TBI
this is my just theorizing.... problem might be there's not enough spark or fuel reaching the cylinder to turn the piston by themselves... meaning that the starter is turning your engine and running at the same time... but how long can the engine last on with the key on and what noises or anything in particular?
Old May 1, 2012 | 08:39 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Bad ign switch? Do you have power on the pink wire coming out of the switch when in the 'on' position?
Old May 3, 2012 | 11:59 AM
Engine: 305 LB9
Definitely combustion happening (its loud, theres no exhaust). No grinding, it runs decently so long as the key is turned. Changed oil recently, new starter, new gas tank and fuel pump, new spark plugs and wire set, new battery, so any and all of those can be eliminated. Getting a new alternator so I'll see if that changes anything.
Old May 4, 2012 | 07:25 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Sounds to me like your ignition switch on the steering column is too far back
Old May 5, 2012 | 08:55 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by penguinpanda0
No grinding, it runs decently so long as the key is turned..
So how can you have the key in the START position without the starter being operated ????
it won't
As noted by others above ;
it appears you are not getting power from the Ign switch in RUN ; switch faulty or out of adjustment
Run a temp wire from Batt Pos to the coil Pos terminal and see if it stays running;
if it does you have confirmed a problem with the Ign switch
( you know the wiring from switch is OK because it runs in start position which uses same wire to coil)
Old May 5, 2012 | 07:36 PM
Engine: 305 LB9
[QUOTE=vetteoz;5264043]So how can you have the key in the START position without the starter being operated ????
I was unsure what was meant by 'grinding', yes the starter functions when I put the key in start. Thanks for the tips. (:
Old May 5, 2012 | 08:28 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If the starter is working ( trying to engage ) when the the engine is running you will have a serious grinding noise from the starter gear hitting the moving flexplate
If no noise from starter with engine running ;then it may be the switch is actually in the RUN position but by being out of adjustment puts the key closer to START position
Old May 27, 2012 | 04:27 PM
Engine: 305 LB9
Sorry I'm back. If the switch is in ON when I turn to start, shouldnt the starter never engage in the first place?
Old May 27, 2012 | 04:51 PM
Engine: 305 LB9
New info: Even when I leave the key at start, it still dies after a few seconds. Also, the engine won't start unless I let the fuel pump run for a bit. Which leads me to believe that the engine is not receiving enough fuel on a constant basis. If I let the pump run for a bit, it has enough fuel to start, but when that gets burned off, it dies. My injectors and fuel pump also remain on even after the key is removed. The only way to turn them off is to unhook the battery. However, this behavioral pattern will not recur until I try to start the engine again. So I have a variety of problems at this point.
Out-Cast
Dec 31, 2015 04:40 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Out-Cast
Aug 17, 2015 10:57 AM
