choke warning light
Old May 14, 2012 | 03:52 PM
mballejos87's Avatar
Car: 1984 camaro
Engine: 305 v8
Transmission: auto 4 speed
choke warning light
ok so i have an 87 camaro 305 and about a year ago to get it running i bought an edelbrock 1405 carb never had problems or warning lights till i washed my engine all of a sudden the choke warning light goes on and off as it pleases i wouldnt car but it makes that buzzing noise does anyone have any clues why now and how i can kill it
Old May 21, 2012 | 04:20 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Choke Revoke
A bad connection at the bulkhead connector can cause the Choke Light to come on.
Also a bad connection to the choke heater.
Review those connections to fix it the right way.
But if you just want to “
kill it (not recommended)
access the Audio Alarm Assembly which is located in the ‘Convenience Center’, which is to the right of the steering column and remove the buzzer.
Here is the choke symbol to help identify the unit:
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old May 21, 2012 | 06:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: choke warning light
There isn't a choke buzzer, the noise comes from the choke relay and is an indication of a charging problem.
Old May 22, 2012 | 10:18 PM
Car: 1984 camaro
Engine: 305 v8
i ment to put an 84 camaro and do you think its the altenator
Old May 22, 2012 | 10:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the choke heater fuse first.
Old May 22, 2012 | 10:33 PM
pumpkin's Avatar
also chec the two wire sometimes three wire oil preasure sending unit. It may be under the distributor, or just above the oil filter on the side of the block.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
fasteddi
Sep 10, 2015 09:32 AM
andy74
Sep 3, 2015 08:41 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
