High beam problems!
Old May 21, 2012 | 10:02 PM
N_da_Mood's Avatar
Car: 1992 Z28 Heritage Edition
High beam problems!
Well, I am not sure whether the problem is in the signal switch or somewhere else but, whenever I go to turn my brights on or off the switch only sometimes works. It will always turn the brights off but I have to hit it sometimes a million times just to get the brights to come on and sometimes when I try to turn on the brights it just turns off the lights... This is not fun to do while driving at night. So is it a mechanical problem in the "blinker Lever" or an electrical issue. If anyone knows of a way to fix this it would probably save my life thanks!
Old May 22, 2012 | 06:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: High beam problems!
Could be a bad switch (bottom of steering column) or an adjustment issue between switch and rod.
JamesC
Old May 22, 2012 | 05:28 PM
N_da_Mood's Avatar
Which rod are you talking about? would it be at the bottom of the switch? The switch at the bottom of the steering column, is that under the dash?
Old May 22, 2012 | 05:43 PM
JamesC's Avatar
Rod from stalk down column to switch at the base of the column (under the dash).
JamesC
Old May 22, 2012 | 05:57 PM
N_da_Mood's Avatar
Alright I will look into it thank you!
Old May 26, 2012 | 03:27 PM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
My switch was bad. $12 part, but a pain in the a-- to change.
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
