ECM vss input
Old May 21, 2012 | 11:23 PM
pumpkin's Avatar
ECM vss input
I am in the middle to end of putting a sbc 400 in my 72 Blazer. I have just about everything worked out and working, except I can not get a seep signal to the computer. I am useing a 4 ppr vss into a drac into the computer. I can't seem to find the info on how to diagnose the components,mainly the drac output signals.
Old May 21, 2012 | 11:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ECM vss input
What computer are you using?
The VSS wiring to computer varies by ECM type
Old May 22, 2012 | 10:53 AM
pumpkin's Avatar
Re: ECM vss input
Its an ebl flash, 747 computer. I am mostly looking for what voltage I should see out of the drac. I did some more testing and I think I have two bad dracs. I get a poor square wave out of them, but when I tap them the signal changes.
Old May 22, 2012 | 11:20 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM vss input
I thought the drac uses 20ppm input? can you change it from your 4k to a 2k and uses a vss buffer to get the optical 2k to the ecm? if not looks like dakota digital sgi-5 would be the answer.
Old May 22, 2012 | 10:30 PM
pumpkin's Avatar
Re: ECM vss input
I made a mistake, its the output that I was looking for. With a little more digging and googling the question diferently I think I found the answere that makes the most sense. The drac output is a 5 volt dc square wave. If this is true I can now dig thruogh more junk and find one that works.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
cheesehomer
Dec 31, 2015 08:48 AM
Jlanz55
Sep 29, 2015 08:55 AM
