going from tbi to carb
Old May 25, 2012 | 12:44 AM
rafterrat_2005's Avatar
Car: 1988 T/A Hatchback
Engine: 5.0 TBI soon to be carbed
Axle/Gears: 10 bolt 3:73 not sure on the gearin
Does anyone have the wiring diagram for an 88 T/A NEED to GET RID of THE darn COMPUTER!!!! Hate these in a car!!!! with size wires and locations and plugging into fuse block on fire wall.
Please help
Old May 25, 2012 | 02:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: going from tbi to carb
https://www.thirdgen.org/carbswap
Old May 25, 2012 | 12:23 PM
This looks like the schematics for the TBI. What wires do I need to get rid of including the different sensors and taking out the A/C unit as well.
Old May 25, 2012 | 07:51 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by rafterrat_2005
What wires do I need to get rid of.
You don't NEED to get rid of any; just disconnect them and make safe
https://www.thirdgen.org/forums/post...339-post3.html
Most however go mad and butcher the harness ,chopping out what is not needed
https://www.thirdgen.org/forums/post...685-post5.html
meaning if at a later date someone wants to put EFI back in they need a new harness
Old May 29, 2012 | 10:18 PM
Seafarer12's Avatar
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
Why do guys hate TBI's? I have never had anymore problem with them than a carb and they have better drivability and fuel economy. Ever since I got a fuel injected car I have never wanted to go back to carbs. I guess I am just old.
Old May 30, 2012 | 10:36 AM
I want to got to carb because you can do just so much more to the motor than having a TBI or fuel injected. I just don't want my car being operated by a computer with all the sensors. They didn't have them in the early '70's and older, and didn't need a rocket scientist to work on them. That's why there aren't that many "backyard mechanics". All because of the computers and technology. Any way that's my thought and possibly a few others out there. And I am in my latter 40's, also
Old May 30, 2012 | 10:17 PM
Seafarer12's Avatar
No offence intended but you can do so much more with fuel injection. Its like having a carb tuner under your hood all the time. I mean no more cold morning hard starts, no more crappy fuel economy, no more tuning the carb because you hit a pot hole or it just getting out of adjustment. Sure TBI can be a little limited because you only have two injectors to work with but it is as basic as it gets. As far as tuning goes you can either jack with it or get someone to do a tune on it. If you are really into it you can install the stuff to run multiple tunes you can swap between on the fly. As far as hard to work on. Really they are easier. I mean they give you trouble codes that tell you what isn't working. All you need is a paper clip to check them. I ran carbs for many years there is no way I would go back to them unless I had no other option but to each his own. Good luck on the swap.
Old May 31, 2012 | 05:11 AM
yea but ya can't install timing gears or higher lobed cams,right? And the sound of a 4 barrel kicking in sounds so good. But if there was a way to bypass those timing sensors to get the above mentioned I might keep it TBI.
Old May 31, 2012 | 06:06 AM
Seafarer12's Avatar
As long as they are within reason. I am running bumped up compression, rv cam, edelbrock intake. take a look at www.tbichips.com/truckmods.htm. Look at some of his projects.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
