87 GTA will NOT turn off with key
Car: 87,88,89 GTA
Engine: 305+350 TPI
Transmission: AUTOMATIC
Hi guys my 87 GTA now runs but it woint shut off with key i have to ground out coil to get it to turn off any leads?? thanbks in advance
Tom
Tom
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 87 GTA will NOT turn off with key
could check if the alternator is backfeeding the switched
ignition-don't know about CS130 alternators,but the
older SI type need a diode or bulb in the turn-on wire
or they will feed voltage out that wire once rotating and
continue to power ignition if there is no diode or bulb
to block the backfeed.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Street Lethal
Apr 30, 2019 12:14 PM
