Indicator lights not working
Old May 26, 2012 | 01:51 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I was driving around for a while last night when I noticed both indicator lights stopped working when I try to indicate. I looked at it this morning and saw the "turn" fuse was blown, tried replacing that and still didn't work. Relays are completely fine too because hazards come on with no problem even after trying it with the blinker relay. Anyone have any idea what it could be?
Old May 26, 2012 | 02:03 PM
Axle/Gears: 3.45
Re: Indicator lights not working
Update: now the hazards have stopped working
Old May 27, 2012 | 06:18 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Check your bulbs. Also, it could be "in"the steering column, there is a relay/switch inside the column that may have gone bad. Kind of a PITA to get to and you'll need a steering wheel puller to get the steering wheel off/back on. Replace all your turn signal relays and fuses also.
Old May 27, 2012 | 01:03 PM
Axle/Gears: 3.45
I think it must be the relay in the column because the indicator lights come on when I put the hazards on (turned out to only be a blown fuse for the hazards) do you have a picture of what the relay looks like? thanks
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
marcusaw
Aug 10, 2015 08:13 AM
