Weird Hacked Starter Wiring Issue
Old Jun 5, 2012 | 08:49 AM
fyancey's Avatar
89 firebird formula, auto with retrofitted th350 trans
Problem: Trying to undo some weird wiring the previous owner did..
In order to start the car, the previous owner, had a pushbutton in the cupholder. Two wires were going to it, through the firewall, and tapping into a large purple wire going to the starter. Instead of drawing power from the normal circuit, he was tapping off the power to the back up lights by switching wires at the neutral safety switch on the hurst promatic 2 shifter. I guess this was popping fuses all the time.. as it blew one on me.
What I have done to troubleshoot: He wasn't getting power by normal means to the starter. I have checked the NSS switch in open and closed positions.. with a voltmeter. I get connectivity. I checked the starter enable relay, with a 12v power supply, and it clicks, and I can get a circuit through there. When everything is connected like it should be... (The NSS wires are not connected to the back up lights, I hear a click at the starter enable relay. I replaced the ignition switch on the rear steering column.. not a fix.
The Key has vats, and is getting the proper resistance at the two pronged lead..
Any idea why he did this? I think he knew what the problem was.. but he lied to me about it. I'm guessing the power issue is before the starter enable relay.. what should I check next? I don't like the idea of tapping onto the power for the backup lights.. i'd rather spend the money and put it back right.
Please help me oh firebird gurus!
-Floyd
Old Jun 5, 2012 | 08:56 AM
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
Re: Weird Hacked Starter Wiring Issue
are you getting keyed power? turn key forward get lights and the whole nine yards?? If so... you are ahead of me a step with my car lol!!
Old Jun 5, 2012 | 09:56 AM
fyancey's Avatar
Yes, The fuel pump cuts, on, power, everything.. just no crank, unless i'm feeding it power from the backup lights. There's something not pushing juice upstream before the starter enable relay.. any idea what? lol
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86Base
Aug 8, 2015 01:34 PM
