Need help with temp and oil pressure gauge
Old Jun 7, 2012 | 08:53 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Oil pressure gauge: With key on, it doesn't blip to max then back to zero. When I start the car it always goes to 60 psi and stays there.
-with IGN on, I can get the needle to max when I disconnect sender wire.
-IGN on and sender wire grounded to negative battery it stays at 0.
Temp gauge: ign on, it never blips to max then back to 100. When I'm letting it warm up in park, I can see the gauge start to move higher a little bit (like it's working fine), then whenever I hit the brakes the needle goes straight to zero.
-can't get gauge to max when sender wire is disconnected.
-gauge stays at the bottom when grounded (100 degrees)
The rest of the gauges work fine.
I don't know what to do next.
Old Jun 7, 2012 | 11:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need help with temp and oil pressure gauge
Originally Posted by 0pyders
Oil pressure gauge:
Gauge and wiring fine ; replace OP sender
Temp gauge:
Gauge or wiring to gauge faulty.
Further testing needed to determine
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
