Starting Problems
Old Jun 12, 2012 | 11:32 AM
fatalicshock's Avatar
Car: 87 Trans Am
Starting Problems
So i just git this 89 Iroc i had to put a new engine in i got it all buttoned up started it up and drove it around then it died out due to timig but after that i tried to start it up and the starter just clicks and wont turn over the motor but if i jump the car it fires up every time and i put 3 diffrent good batterys in it and they all do the same thing
Somebody PLZ help
Old Jun 12, 2012 | 11:40 AM
84firebird1996's Avatar
Car: 1991 Trans Am GTA
Engine: LT-1
Re: Starting Problems
If you jump your car with cables? Like car to car?
Old Jun 12, 2012 | 11:41 AM
Car: 87 Trans Am
Yeap Car to car
Old Jun 12, 2012 | 11:48 AM
Engine: LT-1
If you have a voltage meter you can check how much voltage you are drawing when trying to start.
Old Jun 12, 2012 | 11:53 AM
Engine: LT-1
Something is up with the wires on the battery. Check engine block ground and firewall ground and chassy ground. follow wires and check for any break and rips in the rubber
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
