Headlights went out on the way home.... thank God for fog lights!
Old Jun 13, 2012 | 10:56 PM
VandykeT/A's Avatar
The headlights on my 89 Iroc went out about 15 minutes ago and never came back in. Every other light works perfect just no headlights and the blue high beam symbol isn't lighting up when you flick the dimmer back and forth. The headlight switch is new. They worked fine for about an hour and then all of the sudden they started flickering, came back in for about 10 seconds and then just went out. What could cause this? Anybody have a wiring diagram of the headlights on an 89? I've checked the plug ins under the steering column.
Old Jun 14, 2012 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Headlights went out on the way home.... thank God for fog lights!
I'd double-check that the dimmer switch is still adjusted correctly first, then go from there.
Long ago I was driving in the early morning on the highway. I switched to high beams and was greeted with blackness. That experience put a skid mark on my shorts.
JamesC
Old Jun 14, 2012 | 10:38 AM
VandykeT/A's Avatar
How do you adjust the dimmer switch? I always thought it was a it works or doesn't work kind of thing.
Old Jun 14, 2012 | 02:33 PM
VandykeT/A's Avatar
Ok now I see how the dimmer switch adjusts. I actually replaced it just then and still didn't fix it. I replaced the headlight switch a while back with one from autozone. Whats the odds its bad?
Old Jun 14, 2012 | 06:41 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Probably the head light switch IMO.
GTAman
Mar 15, 2019 11:40 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
mustangman65_79
Aug 12, 2015 06:39 AM
