mini starter wiring
Old Jun 22, 2012 | 05:25 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
mini starter wiring
hey everyone!
project 350/5 speed is going great! just got in loads of parts, and can't wait for this heat wave to end so i can get the car running right.
so, i purchased this mini starter off of ebay ( i believe it's a hitachi) and the connections are different than the stock unit. the mini starter has two (2) big lug terminals (one with wire going into the starter, the other empty) and a blade connection. now i know the positive battery cable goes on the empty lug, it's other smaller wires i have no clue about. i'm guessing they are the switch wires? (just forgot the forum does let you insert pics with out them being hosted somewhere else. can we fix that please?)
anyways that's what's up. i took the starter off 4 years ago and memory isn't my best friend. point me in the right direction, fellas!
Old Jun 22, 2012 | 09:24 PM
gp90gta's Avatar
Car: 1990 GTA
Re: mini starter wiring
The blade terminal your talking about is for the small wire, this is the wire that sends power from the ignition to crank the motor, all other wires go to the large stud.
Old Jun 22, 2012 | 09:57 PM
GTAman's Avatar
you, sir, are awesome! thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
milk
Aug 10, 2015 06:26 PM
