Volts gauge zeros out..on and off
Old Jun 23, 2012 | 08:37 AM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Hello. I am having a weird issue with my 84 camaro. When the car is running the volts gauge will erratically drop off, and then come back up to like 12 volts, then drop off again. Was coming home the other day in the rain and had the fan on to help clear the windows, I could hear the fan slow down to nothing then come back on and then shut off and come back on....while it was doing this I noticed the volts gauge bouncing all over the place. Any idea what could be the problem
onthedl
Old Jun 23, 2012 | 04:55 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Volts gauge zeros out..on and off
It is time to have your charging system tested. Something is not working right or you have a short somewhere. Check your wires going down to your starter from your battery, look for any burnt insulation or something that doesn't look right.
Old Jun 24, 2012 | 10:30 PM
Engine: 355
Good advice there Ed. Going to check in the morning. Many thanks.
onthe dl
Elephantismo
Feb 13, 2019 12:51 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
sahlomonic
Sep 20, 2015 07:15 PM
Jlanz55
Sep 6, 2015 03:05 PM
Glowsock
Sep 6, 2015 06:40 AM
