Everything electrocal dead
Old Jun 28, 2012 | 10:59 AM
DanSchroeder's Avatar
I was driving my 92 Camaro RS v8 yesterday, and the car is relatively new to me so while I was driving I for some reason wanted to see if the hazards worked. I turned them on and off and all my gauges died for about a second. I thought nothing of it at the time. I parked and then 2 hours later went to turn on my car and boom, no electricity to anything. No headlights, radio, or anything. The gauges dont even move. Tried jumping it and still no electricity. I checked the leads for the battery and they seem ok. I have no clue what to do. Someone said a fuse in the engine bay but I have no idea where those are. If anyone could point me in the right direction that would be great.
Old Jun 28, 2012 | 11:49 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Everything electrocal dead
Check the fusible links in the wires down by the starter, I bet one of them is shot. They should be red wires with larger black plastic/rubber pieces on them. I think there are 3 of them total (or at least that is what my car had). If the one going to the alternator was still good, that could explain why your car kept running until you shut it off. The car was getting all its power from the alternator and not the battery.
If they're bad it may be a visibly burned wire, or you may have to test the wire's continuity to be sure.
Old Jun 28, 2012 | 04:10 PM
Thank you so much, that was the problem. One of the wires must have been resting on the exhaust manifolds and just got burnt up. Spliced some wire in and itnfired right up. Thanks again.
Dan
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
Jonas Earl
Sep 27, 2015 07:39 AM
Johnoooooo
Sep 22, 2015 08:55 AM
