My Low Beams Do Not Work Whats Wrong?
Old Jun 28, 2012 | 05:08 PM
benji84cam's Avatar
Car: 84' camaro SC
Engine: 2.8l carb
Only my brights will work if i switch to dims no lights work but if I use my brights only the brights stay on. what are the possibilities and has anyone else had this problem?
Old Jun 28, 2012 | 11:50 PM
napalm368's Avatar
Car: 1986 iroc z28
Transmission: 700-r4
Re: My Low Beams Do Not Work Whats Wrong?
i had similar prob recently. but in my case,,the wiring harness to the low beams were shorting out,due to bieng so old.(not sure what condition yours are in) i replaced my harnesses and prob went away.,,thats one possibility.hope it helps.
Old Jun 29, 2012 | 01:07 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Make sure the switch clicks to the other side when you depress the lever. Sometimes the switch is worn out and does not go into (second gear ha-ha). If so you will need to replace the switch in the column.
Old Jul 2, 2012 | 06:05 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If the Hi/Lo beam switch is the culprit, it has an adjustment that could resolve your problem. (http://www.austinthirdgen.org/index.php?pid=16)
Try raising or lowering the steering wheel. Does it change anything?
I would also recommend grabbing a test light and checking for power at the tan wire at the headlights (outer). If you have power there, check the connectors and also lights. There is a chance that both low beams are burned out.
Hope this helps.
Lou
Jake_92RS
Jan 28, 2020 10:37 PM
Fronzizzle
Aug 19, 2015 01:36 PM
jackhammer
Aug 15, 2015 10:04 PM
perZ
Aug 15, 2015 01:17 PM
dhonda200
Aug 11, 2015 11:50 PM
