92 rs camaro ¿computer or memcal bad?
Old Jun 25, 2012 | 05:53 PM
Mudd_duck's Avatar
Car: 1988 Pontiac T/A; 1992 Camaro RS
Engine: T.B.I 305; MPFI 3.1
Ok, i bought a 92 camaro with the 3.1 engine (needed a fuel pump)
Replaced fuel pump, cleaned fuel rail and injectors and lines...
The ppl i bought the car from said it had a bad computer......
The car had 2 computers and 2 memcals in the car when i got it....
With either comp box hooked up i have the same issue, so i dont think its the actual computer box..
If i insert one memcal in, turn on ignition i get no code twelve and the fan kicks on as soon as the switch is on, the car WILL crank and runs(sh*tty), but runs....
If i put the other memcal in its place i get code twelve, no fan, and ?no fire/gas?....
Does anyone here have any idea as 2 what could possibly be wrong here????
Old Jun 26, 2012 | 01:38 PM
Mudd_duck's Avatar
Re: 92 rs camaro ¿computer or memcal bad?
:bump: need assistance
Old Jun 26, 2012 | 07:35 PM
Mudd_duck's Avatar
Well, im going 2 the junkyard 2morrow and pull a computer or somethin.... maybe ill get lucky...
Old Jun 26, 2012 | 08:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
sounds like a bad memcal, the azty is the best code for a 3.1L v6 with the 700r4 transmission. I have a few v6 memcals that would work or I could reprogram for you, let me know if you need assistance.
Old Jun 26, 2012 | 08:04 PM
Mudd_duck's Avatar
"azty"? Is that printed on the memcal?
Old Jun 26, 2012 | 08:10 PM
Engine: Lb9
Transmission: M20
yes, The letters on the silver sticker on the memcal is called the broad cast code.
http://www.gearhead-efi.com/BCCFind/
Old Jun 26, 2012 | 08:19 PM
Mudd_duck's Avatar
The one that will crank the car is axdh 0179
The other one is aujw 0976
Are either those the right #s for my car?
Old Jun 26, 2012 | 08:22 PM
Engine: Lb9
Transmission: M20
BCC= AXDH0179 Scan id= 9994 Part number= 16160178
Release date= 09/10/90 Engine size= 3.8 Trans Type= Auto trans
ECM/PCM: ECM #16141470
Used in cars:
Oldsmobile Buick
Possibly used in:
98 TOURING SEDAN 98 REGENCY ELITE PARK AVENUE ULTRA
PARK AVENUE
Options:
With F17 TRANSAXLE, FINAL DRIVE, 2.84 RATIO
With L27 3.8L GAS 6 CYL SFI V6
With NA5 FEDERAL REQUIREMENTS
Old Jun 26, 2012 | 08:23 PM
Engine: Lb9
Transmission: M20
the aujw is the one that should work in your car with a 1227730 ecm
Old Jun 26, 2012 | 08:31 PM
Mudd_duck's Avatar
Ok, but when this one is hooked up i get no fuel... If i spray start fluid in the intake itll fire over but other than that nothing....
Its like its not controling the ?injectors?
Old Jun 26, 2012 | 08:36 PM
Engine: Lb9
Transmission: M20
you stated above the one memcal will run but bad a no communication with the ecm this should be your aujw memcal in limp home mode.
Old Jun 26, 2012 | 08:42 PM
Mudd_duck's Avatar
Thats the one that throws code twelve but no crank,
The other has no code but will crank....
Old Jun 26, 2012 | 08:58 PM
Engine: Lb9
Transmission: M20
maybe its a vats issue with that memcal cutting injector pulse.
Old Jun 26, 2012 | 09:02 PM
Mudd_duck's Avatar
Im going 2 a junkyard tomorrow, is there a list or something of usable computers/memcals?
Old Jun 26, 2012 | 09:08 PM
Engine: Lb9
Transmission: M20
any of these ecm numbers 1227730 / 16196344 / 16198262
you can see some of the bcc here, vats started in 89
http://www.3rdgenformula.com/90/promcodes.htm
http://www.3rdgenformula.com/91/promcodes.htm
http://www.3rdgenformula.com/92/promcodes.htm
Old Jun 26, 2012 | 09:12 PM
Engine: Lb9
Transmission: M20
you can see if you are getting the vats signal from the passkey module too the ecm on the ecm pin f10 dark blue wire it should be 30hz 50-60 %
Old Jun 26, 2012 | 09:17 PM
Mudd_duck's Avatar
Thats awesome, thanks man, hopefully i can find something tomorrow...
Old Jun 26, 2012 | 09:23 PM
Engine: Lb9
Transmission: M20
you might check that vats before you start buying unnecessary parts. You can check this with a vom that has the hz setting koeo or cranking.
Old Jun 26, 2012 | 10:53 PM
Mudd_duck's Avatar
What exactly do i need 2 do to check the vats, ill try that before i go to the jy
Old Jun 26, 2012 | 11:03 PM
Engine: Lb9
Transmission: M20
I listed the testing above use a volt ohm meter with a hz setting with the key on engine off or cranking and see if you get a signal to the ecm pin f10 dark blue wire. You can bypass the key resister bye installing the correct resister across the harness see link below, and it may fix the issue.
https://www.thirdgen.org/forums/elec...stor-help.html
Old Jun 28, 2012 | 04:08 PM
Mudd_duck's Avatar
Ok so the junkyard was a waste of time, and as far as vats goes, i went 2 a dealership, and found out the key was a #12, 6040 ohms?
Put 3 resistors together to get 5940, that should be within tolerance...
Plugged into harness clip.
Still nothing....
Any ideas?
Old Jun 28, 2012 | 04:19 PM
Engine: Lb9
Transmission: M20
so you are not getting a hz signal too the ecm ?
Old Jun 28, 2012 | 04:27 PM
Mudd_duck's Avatar
Lol still not exactly 100% on where this dark blue wire is you speak of, there are at least 3 blue wires on the ecm..... And i dont wanna mess anything up by poking around in somethin i dont know anything about, Without doing some homework...
Are there any pics or illustraition of the ecm wiring...?
Old Jun 28, 2012 | 05:05 PM
Engine: Lb9
Transmission: M20
unplug the yellow or green connector on the ecm. this is for tpi but the input f10 is the same for vats.
Old Jun 29, 2012 | 09:50 AM
Mudd_duck's Avatar
Ok, now that is that, i dont believe the dmm i have has a setting to measure hz... Is there anything else can be done without measuring the hz?
Or am gonna have to run out and get a new multimeter?
Old Jun 29, 2012 | 10:19 AM
Engine: Lb9
Transmission: M20
I don't know that you can read the frequency any other way. If you get a vom with a hz setting you can see for sure if its a vats issue or not. If it is you can bypass it with a modulator or have the memcal reprogramed to remove the vats. I have reprogramed out the vats in my two vehicles.
http://www.ebay.com/itm/GM-VATS-or-P...069889&vxp=mtr
Old Jun 29, 2012 | 10:32 AM
Mudd_duck's Avatar
Ok... Well leaning towards it being the vats module just based on the assumption i have everything but fuel.... I probably should have mention before, the car has a push button start wired inline to the starter....
Judging by what ive read on this site, I think it was a vats issue that the previous owner and "mechanic" misdiagnosed as a computer issue..
Old Jul 2, 2012 | 10:02 PM
Engine: Lb9
Transmission: M20
any progress ?
Frozer!!!
Jan 19, 2024 04:55 PM
TheJoeY88
Dec 31, 2016 07:30 PM
matthew911
Aug 12, 2015 09:38 AM
Bradsaundry
Aug 12, 2015 12:34 AM
