Voltage regulator or alternator?
Old Jul 5, 2012 | 09:46 AM
hydrawidow's Avatar
Car: 92 Camaro RS
I have a 92 Camaro 5.0 motor, I was driving down the road and lately have noticed with the A/C off, radio off, and lights off the volt meter read in between the halfway mark and the second mark (charging low). The past couple of days I had to jump start the battery to get it started and it stayed running but last night the volt meter fluxuated from the bottom mark in the red back to the center red back and forth.
The car died and will not start now.
I'm thinking voltage regulator but it is the original alternator so my question is, is the voltage regulator built inside of the alternator to where if I replace the alternator I'm getting a new regulator, or is it a separate component on it's own?
Old Jul 5, 2012 | 09:51 AM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: Voltage regulator or alternator?
The alternator is internally regulated.
Mark.
Old Jul 5, 2012 | 10:27 AM
hydrawidow's Avatar
Car: 92 Camaro RS
Perfect. Thanks Mark!
Old Jul 5, 2012 | 10:54 AM
hydrawidow's Avatar
Car: 92 Camaro RS
Another question... To remove the alternator, what size torx bit is required to remove the mounting bolts?
Normally there are bolts but it looks like there are torx screws that hold it on the bracket.
Old Jul 5, 2012 | 11:34 AM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Should be here
https://www.thirdgen.org/forums/elec...tor-bolts.html
Old Jul 5, 2012 | 11:53 AM
hydrawidow's Avatar
Car: 92 Camaro RS
Perfect, thanks a bunch Richboll.
gixxer92
May 18, 2017 11:20 AM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
