Mystery Wire Connected to Battery
Old Jul 5, 2012 | 04:22 PM
Jet_91's Avatar
Car: 1986 Trans Am
Engine: 350 SBC
Hey guys, I've got a large blue wire that was connected to the battery of my 86 T/A when I bought it, and for the life of me I can't figure out its purpose. I know it's not stock, but I figured if anyone would know it would be TG.org. haha
I followed it back through the firewall and I can see it goes under my stereo/heater controls and follows along my center console then disappears. I wouldn't think much of it other than the fact that it's pulling spark from somewhere. Quite a lot actually. But I've had it disconnected for a while now and as far as I can tell everything on the car works just fine. :/
Any ideas?
Old Jul 5, 2012 | 04:29 PM
nhgator's Avatar
Car: 1985 T/A
Re: Mystery Wire Connected to Battery
Looks like power for a rear mounted amp
Old Jul 5, 2012 | 04:33 PM
Jet_91's Avatar
Car: 1986 Trans Am
Engine: 350 SBC
That's what I suspected as there was a large sub in the back when I bought it, but I removed it when I got it back home so if that was the case it shouldn't still be pulling spark I wouldn't think.
Old Jul 5, 2012 | 04:41 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I would second the guess for an amp.
When you pulled the sub out did it have the speaker wires running to it. If so they should have led straight to the amp.
Without an amp there should be no draw but maybe not if they put in a digital capacitor etc. I would look in the spare tire well or the rear storage box area to see if there is any signs of that wire end there.
Old Aug 3, 2012 | 03:09 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
that definitly powered an amp , the clear clamps holds the fuse, just twist it open and pull fuse then unscrew from battery.
Old Aug 3, 2012 | 03:46 PM
Jet_91's Avatar
Car: 1986 Trans Am
Engine: 350 SBC
It seems everyone I talk to also agrees with you guys that it's an amp fuse. I just can't figure it out because there's just no sign of one anywhere! There's just no place left to hide one other than under the carpet. haha Oh well, I guess I'll just disconnect it and forget it.
Thanks guys!
Old Aug 3, 2012 | 07:12 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
That is power for an amp.
Old Aug 3, 2012 | 09:50 PM
82tarecaro's Avatar
Disconnect it at the battery if you aren't using it so it doesn't short on anything.
Old Aug 10, 2012 | 05:00 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Or just pull the fuse so the power stops there and doesnt short anything. beats having to re set your radio settings if it means disconecting terminals. removing the fuse is the easiest way. just make sure to save it as on of those is like 5 bucks
Old Aug 10, 2012 | 05:46 PM
Cat Amanigh's Avatar
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
Did you ever consider under the seat? I do a lot of amp installs under seat because of the clean look it provides, being totally hidden and all.
Old Aug 10, 2012 | 07:13 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
My power amp is sitting on the shelf under the driver's side access panel.
Old Aug 11, 2012 | 03:57 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
So... the po probably removed the amp before he sold you the car.
Old Aug 11, 2012 | 03:00 PM
Jet_91's Avatar
Car: 1986 Trans Am
Engine: 350 SBC
It kind of looks the way, but if so I can't figure out why it would still be pulling spark. I haven't looked under the seats yet, I'll try there later today.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
1992Vortec
Aug 31, 2015 08:05 PM
stalkier
Aug 13, 2015 12:59 PM
