Want to use vats steering column in my old truck with tpi.
Old Jul 6, 2012 | 05:04 PM
rocn7roc's Avatar
Hi I need some imput, I have parted out a wrecked 91 trans Am GTA for the parts I need for my 57 chevy truck project. I plan on using the Gta column, vats decoder ,ECM and the tpi engine , Can I simply follow the wiring diagram on the vats in this forum. Column wiring to decoder to Ecm and the enable start relay? Also does anyone no the part no of that relay as everything is in a heap yet except I made the engine harness and that is ready. I also own a 89 Rs convertible! Thanks for any imput Mike
Old Jul 16, 2012 | 08:55 AM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: Want to use vats steering column in my old truck with tpi.
It should work fine as long as you connect everything following the diagrams.
Amillionoh7
Sep 11, 2015 11:36 AM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
