CB Radio?
Old Jul 16, 2012 | 04:01 AM
Brynpowers's Avatar
Car: 1987 Firebird
Engine: 2.8l (173cid)
CB Radio?
Okay so i have an 87 firebird and i have always wanted a cb radio to put in my car. well i have seen many youtube videos on just wiring them to your fuze box like to the radio fuze i was not sure if this was safe. and my plan was to do that. also what is a good cb to buy and do i have to wire any thing to my speakers? Can i get a built in speaker (to the cb)?
Here are some the cb i have looked at:
Cobra Compact 40-Channel CB Radio
Uniden Pro 510 XL Car Kit
Uniden Pro 520 XL
and lots of others.
Old Jul 16, 2012 | 08:49 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: CB Radio?
Yes, you can wire it to the radio power, that would be a good source.
The Uniden 510/520 is a great radio, I've used them a lot in the past, cannot kill these little suckers!
They come with an integrated speaker so you don't need to buy an external speaker.
The 520 is a little more expensive than the 510 because it has some extra features that you might not even use, like the RF Gain **** and PA (if you connect an optional external speaker on the outside of your vehicle).
So the Uniden is a very good choice.
Old Jul 16, 2012 | 02:34 PM
Brynpowers's Avatar
Car: 1987 Firebird
Re: CB Radio?
okay thanks. do you think i should buy the one that you plug into an cigarette lighter and the antena or just wire it to my fuze box?
Old Jul 16, 2012 | 04:51 PM
BigBadLou's Avatar
Engine: TPI
Re: CB Radio?
If you expect to move the radio between cars, it would be easier to have the magnetic mount antenna and cigarette lighter plug.
If you want to make it a permanent installation, I would recommend to plug the power into the fuse box and install a permanent antenna, which is better due to no cable coming from the outside through weather stripping.
So it is your choice.
Old Jul 16, 2012 | 11:04 PM
Brynpowers's Avatar
Car: 1987 Firebird
Re: CB Radio?
i think ill wire it to fuze box and buy a magnetic antenna because i dont want a huge one on the top of my car...
Old Jul 25, 2012 | 04:30 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: CB Radio?
You don't need a huge "permanent" antenna. It just needs to be taller than the are. Also, it should be at least 3' above the car for it's best coverage.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
