installing vats in 87 iroc(having trouble)
Old Jul 17, 2012 | 04:44 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Heya,
Im trying to install a vats module into my 87 so I can use an 88gta 350 prom.
My 87 has a 70's reproduction Gm 350 crate motor in it.(came with a 305)
The guy I bought it from left the 305 injection stuff in place. I plan to switch to 350 injectors so new prom will be needed.
I happened to have this prom laying around from a past project that didnt pan out. And seeing as how an 87 350 prom is a Bitch to find in a junkyard Im going this route, since I have no money to order a 350 prom(or have mine reflashed) at this time.
for my purposes here can we go on the assumption that the current parts I have are what I must use at this time and that no other parts can be aquired in the forseable future.
It seemed simple enough.
I added a pin to B6 in my ecu harness and connected that to dark blue on the vats.
Orange on vats to constant 12v
pink/black on vats to 12v in run.
black/white on vats to ground.
wired the resistors between purple/black and white/black on vats.(measured the key to be 7.44k ohms so should be blank 13)Initially a locksmith told me it was blank 12 but when I took my multimeter to it came to 7.44. Initially I tried 7.54k ohms and no good, so reduced it to 7.41 and still a no go on the injectors.
The ecu is throwing a code 46, indicating something to do with a general vats failure. I am not getting a code 53 so Im going on the assumption that the ecu IS getting a signal from vats to Not turn on the injectors.
While cranking with my multimeter checking voltage between B6 on the ecu and ground I get 5v so that seems good.
I guess ultimately Im wondering if by connecting the resistors between purple/black and white black(assuming its the right resistance) that should in theory make the Vats think its the right key?
Old Jul 17, 2012 | 06:59 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: installing vats in 87 iroc(having trouble)
Code 46 isn't a VATS failure. It's working by NOT sending a signal to the ECM by GROUNDING the 5V coming out of the ECM at a rate of 30Hz. Which is why the ECM is disabling the fuel injection.
Try the lower resistance first. If that's a no-go, well, you need to start at #1 and work your way up. You need to turn the ignition off for about a minute between tries to let the timer in the VATS reset.
And code 53 is only set while the trouble exists... It doesn't stay in the memory like, say, code 33.
Old Jul 17, 2012 | 08:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
This might be simpler.
http://www.bakerelectronix.com/products_vats/
No key or VATS module needed
Supplies the fuel enable signal direct to the ECM
All assumes that the VATS module is known as working correctly?
Do you know that?
Old Jul 17, 2012 | 08:27 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
always thought VATS started in 89 for the fbodys? i figured 88 would be fine.....unless the birds got it a year before the camaros. like the corvette who got it in 86
Old Jul 17, 2012 | 08:35 PM
Twin_Turbo's Avatar
Why not get a copy of said PROM (Apyp apyu???), edit out the VATS, burn and install w/ memcal adapter.. a whole lot easier tha installing vats.
Old Jul 17, 2012 | 08:46 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
My '88 GTA has VATS and I'm getting my prom reprogramed as I write this post.
Old Jul 17, 2012 | 10:01 PM
Engine: 383 HSR EBL
I would if I had any money at the moment, as no one locally can reprogram my prom this is the route I want to go since it doesnt require buying additional parts., I guess like maverick said Ill just start with resistance value 1 and work from there.
Thanks guys.
kyleb24
Aug 15, 2015 08:24 AM
stalkier
Aug 13, 2015 12:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
djmarch
Aug 9, 2015 05:27 PM
