1992 Speedo and Tach now working great!
Old Jul 27, 2012 | 02:41 PM
rodneyrb's Avatar
Car: 1992 Pontiac Firebird
Engine: 04' 5.3 Liter
Transmission: LS1 T56
I bought the Dakota Digital SG-8 for the tach and the SG-5 for the speedo. I had a little difficulty with the speedo at first, I ended up setting it so read too high and then pressed and held the dn button until accurate. I did this along side my garmin as its pretty close.
The SG-8 was a little harder, could not get that tach to read accurate for anything. Then I called tech support, they were very helpful. When using a V6 tach with a LS engine, you need to set it to 4 cylinders, go figure! It is dead on accurate with no fluctuations or jumping around. I tested this with a computer plugged in to compare it against the ECM.
Attached Thumbnails 1992 Speedo and Tach now working great!-2012-07-22-11.54.26.jpg
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Thirim
Aug 13, 2015 03:09 PM
stalkier
Aug 7, 2015 04:49 AM
